SPD cleats accessories/spares
I've just gone and bought SPD shoes and cleats (Shimano). I don't think I'd tightened them properly, and on my second trip, I pull my foot in a strange way, and the cleat become lose. I lost a screw and the plate that has two holes for the screws. I looked all over the road, but couldn't see them.
Other than buying new cleats, is there a place to get screws and the little cover? If so, what is the names of the bits I'm looking for, so I can look on the internet?
Thanks in advance
gaz
Cycle Camera TV
South Croydon
i can't help you with replacments as i don't use that model.
but lesson of the day for cleats: do them up sa tight as you can.
ianrauk
Tattooed Beat Messiah
Rides Ti2
Just pop in to one of your lbs's & explain the situation. They may have a few lying about in the bottom of a tool box.
Thanks in advance
montage
God Almighty
Bethlehem
My LBS just replaced the bolt :smile: (then again I was getting a brake serviced at the time ....didnt go in just for the bolt)
Edinburgh
Are you talking about the plate that's inside the sole of the shoe? Are you sure it hasn't just moved inside the shoe?
Matthew
M
Mike8782
Thanks for the ideas.
By the way, MM, no, it's the external part. There's an internal part which remained in the shoe. I've attached a jpeg. Each cleat has two screws and one thing with two holes for the screws. I've lost that one thing, plus one screw.
imgres
Edinburgh
Ah, I see. You mean the thing in the bottom left of that picture. Gotcha. ;)
If you can't get a free one you can always buy a spare set of cleats and borrow the part. They're only about £5-6 and you'll need them eventually.
Matthew
Gerry Attrick
Matthew
Flippin' 'eck, where do you buy your SPD cleats? I'll have six pairs at that price!
Edinburgh
xx( I could have sworn I'd seen them that cheap but on looking they don't seem to exist. Best I can find is actually about £12 posted. At that price it almost seems a better idea to spring for some M520s with cleats which would be just under £22 posted. That way you get some pedals for your other bikes (which you WILL buy).
Matthew
