T4tomo
Obviously if your running normal 240V power outside thru your garden it needs to be be in armoured cable.
What is the rules with 24VDC? I.e. if I step down the power using a 24V 36W driver to connect to LED lighting strips rated for outdoor use (IP68), can I run use unprotected 2 core cable outside to connect everything up (with any connections in IP65 rated boxes).
For clarity the Driver and controller will be inside house (or inside IP65 rate protection box)
