Spanner sizes
Tin Pot
I seem to have lost all dozen or so spanners somewhere, what's the size I need to buy for the pedal nut?
Cheers
TP
Overconfidentii Vulgaris
15mm usually.
Edit to add that clearance may be tight so a dedicated pedal spanner is a good idea.:okay:
ayceejay
Rural Quebec
While we are at it - check the recommended torque and grease/thread locker as I am sure this is where a lot of those mysterious creaks emanate from.
Tin Pot
Tin Pot
You can't kid a kidder...
I have loads of Allen keys - someone needs to invent an Allen key recycling scheme.
Torque and grease can feck right off.
ayceejay
Rural Quebec
As can you.
Torque is debatable but if you'd like to take your pedals off again at some point in the future, adding a spot of grease would be a good move.;)
