Is there any reason I can't use these as spacers for a fixie hub?
swee'pea99 Legendary Member 11 May 2009 #1 Is there any reason I can't use these as spacers for a fixie hub?
4F Active member of Helmets Are Sh*t Lobby Location Suffolk. 11 May 2009 #2 swee said: these[/URL] as spacers for a fixie hub? Click to expand... Should be fine
R rustychisel Well-Known Member Location Adelaide, Australia 12 May 2009 #3 They're heavy. Do you need 60? Why not go down to your local hardware store and spend 20p?
OP OP swee'pea99 Legendary Member 12 May 2009 #4 Thanks chaps - much appreciated. I probably will go down the hardware store - I just wanted to know whether 'ones like these' would be ok.
