south wales newbee
Betsiboo123
Gotta Cannondale Caad8 with mainly Tiagra gear. standard Cannondale brakes. what size brakes would i be lookinug at to upgrade? looking at either Ultegra or 105 thanks
Shaun
Founder
I've moved your post here as you're likely to get a better response in the Know How forum. :smile:
Cheers,
Shaun :biggrin:
1st question - why?
If you are looking at increased braking power it seems to have been established that a pad change makes by far the most difference, in fact Cheesney Hawkes went from Tiagra to 105 calipers with no percieved difference in stopping.
If it is to add nicer looking components, then it is upto you.
Not 100% but I think both 105 & Ultegra only come in short drop sizes...which will fit the caad8
