Notafettler
Son dynamo
Have front light but needs to be moved up to handlebar
https://www.sjscycles.co.uk/lightin...dlight-bracket-for-delux-milled-318-mm-clamp/
No rear light so should get this?
https://www.sjscycles.co.uk/lighting/schmidt-rear-light-rack-mount-50mm-black-red/
Will give it to lbs to set up but not sure I shouldn't get some cable as well pacifically
https://www.sjscycles.co.uk/dynamos...age-protection-190cm-long-plugs-fitted-black/
Or should I just leave it to them. The cable on the front light is to short as it will be moved up to the handle bar. Its annoying me as I don't want to buy stuff and not use it.
