Skipper9999
- South Shields
Son 28 dynamo / Busch&Muller IQ Cyo N Plus 60lux front / B&M 4D lite plus rear
I have the above set up on my bike and not sure if it's doing what it should?
For the early part of the bikes life I only had the front light fitted and it worked well. When at last I found some decent cable to run to the back I fitted that back on the bike.(it looks proper smart now).
Now which I think is obvious is that the front light is not quite as bright (or is that my mind) as it was ?
Now I am also sure its all AC power so the cable connection will not matter as long as the rear light is run from the front ?
The rear light has what looks like a switch on the top that does not do anything? is that a cable entry hole on the top and the switch is not a switch but in fact a connector?
What sort of brightness should I expect from the rear light?
I understand, I think that when I stop the bike the rear light will continue to glow ever so dimmer for an age unless I short out the 2 prongs on the outside of the light (but it still comes back on) ?
Any ideas out there ????
Skipper
Skipper
