I'll try explain this as best I can, and I'll get a couple of pics up as soon as I can.
The problem is with my front wheel. When I take the weight of the frame in
my hand there's a bit of a judder and it feels like something is loose. I removed the wheel, the stem and the drops. I couldn't see how I would remove the fork, and didn't want to make things worse so just put everything back together. I was hesitant to remove the brakes.
I probably just need to grow a pair a d take it apart, but what do I need to do to get the fork off the frame, and does it sound like my problem is a loose bolt?
**Title should be 'some give between'. Duh
**Title may be a but misleading, but hopefully someone gets the gist of it
