aberal
- Midlothian
Interesting article picked up via Twitter. http://www.treehugger.com/bikes/cyc...when-solution-easy-mandatory-side-guards.html
not a solution at all - not all deaths are from being dragged under the rear wheels.
Never position yourself to the side of a lorry in the same lane and you avoid the risk completly
Many of the deaths have been caused by the lorry putting itself on the outside of the cyclists!
yes.... after the cylclist pulled up on the left of the lane?
I'd say it is a solution - one of many - not the solution. IIRC, there are construction site vehicles that are exempt from having side guards. It would be worth examining just how spurious the justification for that is.
In which case, I'd want to see what risks are involved on site and whether it's simply a question of exporting that risk to the public highways without having to improve safety, on or off road.I'm afraid there probably is a justification. Pass a couple of big construction sites on the commute and the rough ground the tippers traverse has to be seen to be believed. Must be same or more so where they go to drop off @ landfill.
It's probably simple to design a mechanism to draw up the side protection for off road use. Unfortunately like other life saving concepts its probably not financially viable enough for any private company to research and design it.
while I accept CopperCyclist's greater wisdom on this - if Cemex can do it, why can't the others?I'm afraid there probably is a justification. Pass a couple of big construction sites on the commute and the rough ground the tippers traverse has to be seen to be believed. Must be same or more so where they go to drop off @ landfill.
Follow the guidance of cyclecraft and stop in primary position, do not allow any vehicle to share the same lane alongside you
So it is impossible to avoid the risk entirely.Never position yourself to the side of a lorry in the same lane and you avoid the risk completly
