Jim Cardiff
TA Cyclotouriste 185mm cranks (inc. dustcaps) and 3 rings Cranks in excellent condition. Rings- 52t outer (used but nice) 50t outer (boxed and unused) 34t inner/middle (boxed and unused) + full set of bolts to set up as double. This is everything needed to set up as a double - the 34t ring can be used as an inner on a double or triple setup, or a middle for a triple. For a triple, a set of longer sleeve nuts would be needed (plus another ring!) - £65.00
