[SOLD] Specialized Stumpjumper Expert Carbon, Large
JhnBssll
Suffolk
I'm reluctantly parting with my Stumpjumper to make space for a new build. I've owned this bike from new since 2017, in which time Strava reliably tells me it's only covered 234 miles. It has a few scuffs but overall is in excellent condition having been regularly maintained. I've just replaced the discs and pads, the chain and cassette have loads of life left and the tyres are nearly new.
This is the 6Fattie model which originally came with 27.5" Roval Traverse wheels and 27.5+ tyres. I converted it to a mullet setup with a pair of Roval Traverse MX wheels so it is now running a 29" front and 27.5" rear wheel, improving an already great ride. It could be easily returned to a 27.5+ setup by its new owner with a new front wheel and a pair of plus tyres.
135mm rear wheel travel from the top of the range Fox Float Factory DPS shock and 150mm up front from the super smooth Fox 34 Plus Performance Elite forks mean this bike is equally as happy flying down hills as it is pedalling up them.
Full spec as follows:
Frame - FACT 9m carbon, Trail 6Fattie Geometry, FACT IS carbon construction, M5 alloy rear triangle, SWAT Door integration, PF30 BB, fully enclosed internal cable routing, 148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 135mm travel
Rear Shock - FOX FLOAT Factory DPS, AUTOSAG, Rx Trail Tune, Kashima coating, 197x47.6mm
Fork - FOX 34 Plus Performance Elite, 150mm travel, 3-position compression adjust, tapered steerer, 51mm offset, 15mm thru-axle
Headset - Hella Flush, 1-1/8" and 1-1/2" threadless, Campy style upper w/ 1-1/2" lower, cartridge bearings
Stem - Hope, Red
Handlebars - Specialized, 7050 alloy, 8-backsweep, 6-upsweep, 10mm rise, 750mm, 31.8mm
Grips - Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, L/XL: XL thickness
Brakes - Shimano XT hydraulic; 203mm front, 180mm rear
Rear Derailleur - SRAM X01, 11-speed, carbon cage
Shifter - SRAM X1, 11-speed, trigger
Cassette - SRAM XG-1180, 11-speed, 10-42t
Chain - SRAM PC-X1, 11-speed
Crankset - Custom SRAM S-2200, carbon, PF30 spindle, 28T, direct mount
BB - SRAM, PF30, OS press-in bearings, sealed cartridge
This really is a cracking bike and I'll be sad to see it go. If you have any questions please drop me a message. I'm happy to accompany any serious potential buyers on a test ride locally, you won't be disappointed :smile:
£1895, will consider sensible offers. Located in Claydon, just outside Ipswich - collection only. Thanks for reading!
JhnBssll
JhnBssll
Suffolk
Price dropped to £1595 ono :okay:
