PhunkyPhil
Regular
- Colchester
I am selling a Fizik Kurve Bull which is a saddle that adapts to your every twist and turn.
Specification:
Shell - Re:flex Composite
Cover - Advanced Elastic Cover
Rail - Mobius Cold Forged Alluminium
Weight - 220 gr
Dimensions - 265 x 146 mm
Wingflex sides allows free thigh movement
Rails: 7x9mm Oval Alloy Mobius Rail
I.C.S. ready to accept Fizik bags and lights
Saddle comfort is usually given by the shape and foam on top of the base. With Kurve the comfort is given by the base and the surrounding elements. Kurve is formed from four elements; Re:Flex, Wing Flex™, Mobius Rail, Tuner
RE:FLEX: Re:Flex constructed base of all Kurve saddles, are sensory receptors, responding the body's every twist and turn. The Re:Flex construction is made around thermoplastic composite materials which are layered to provide superior support and comfort. The benefits of Re:Flex are the saddle follows very movement of our sitting contact points and so optimizes the interaction you have with your Kurve saddle.
WING FLEX™: The Wing Flex™ shell flexes downward in the critical area where the inner thighs contact the saddle. Whether the rider has big or small thighs, or a wide or narrow pelvis, the saddle adapts perfectly to the rider.
MOBIUS RAIL™: The design of the Kurve saddle employs a new type of aluminium supporting rail, The Mobius Rail™. Mobius is a circular rail construction that has no beginning and no end. Made from cold forged 2014-T6 alloy aluminium it provides the rail and shell with greater flexibility and support. Unlike a traditional saddle rail, the potential pressure points caused by the rail insertion areas are eliminated.
TUNER: Tuner is an interchangeable tension system, which allows the rider to customize their level of Re:Flex. There are 2 tuner tension levels: slack and rigid (or soft and hard). The rider can personalise the saddle tension by simply changing the nose mounted clip-on insert.
I would like £120 and I will pay the postage and would prefer PayPal payment.
Regards,
Philip
Specification:
Weight - 220 gr
Regards,
Philip
