SOLD: KTM Revelator Sky Di2 57cm Frameset - £500.
russ.will
Slimboy Fat
The Fen Edge
KTM Revelator Sky Di2 57cm Frameset Inc F8 full carbon fork. Never crashed or dropped. A few minor marks from year round use.Renamed Prime in current model range, its also the same frame as the Canic CXC gravel/cross bike, although that was never sold with a Di2 option.
- Flat mount calipers (140mm rear, 160/140mm front.
- Full internal cable/hose routing.
- In-frame seat post clamp.
- Bolt thru axles. See note below.
Includes Richey WCS alloy seat stem and bar stem. Headset and bottom bracket both replaced within the last year. I will leave the original (over long) brake hoses in place to facilitate threading new ones internally.
Please note: you will need to add a 5mm headset spacer to replace the Fourier under stem Di2 mount.
There is one modification from original. The 15mm front thru axle has been sleeved down to 12mm (and bonded in place) as 15mm is too restrictive on road wheelset choice.
Will post to mainland UK for £15. Further afield? Please PM to discuss.
For more detail, see:
https://www.damianharriscycles.co.uk/prod/rac_14190_kt/ktm-revelator-sky-prime-2018-road-bike
http://www.flidistribution.co.uk/blog/new-2021-ktm-canic-cxc-framesets-available-to-order
543323
543324
543325
543326
543327
543328
543329
543330
