kfinlay
Must Try Harder
- Fife, Scotland
Having a clear out of parts that are no longer needed/have been used to help with bike fit/bought in error etc.
Pictures of all parts at http://www.starperformance.co.uk/kf/bikepartclearout.htm
Any questions just ask, I'll get back to you as soon as I can.
Payment by Paypal Gift or cash on collection from Fife Scotland or Gyle Area, Edinburgh.
Charge Spoon saddle, NOW SOLD
Cro-Mo rails, Black (although really is dark grey).
Slight scuff to rear side but nothing bad
Deda Zero100 Seatpost, NOW SOLD
31.6mm dia, 25mm setback.
New condition, tried as part of my bike fit but too much setback so saddle won't go far enough forward.
There is a light mark at the bottom of the post but this is now it arrived. Cheapest I can find is Ribble for £46
White Seatpost, NOW SOLD
27.2mm dia, 10mm setback, cut down from 400mm to approx 350mm. Feels surprisingly light too.
Insertion marks on shaft starting about 10cm from cradle. Good to buy if you are trying to sort out your bike fit or for your winter bike - this is what I used it for.
Deda Newton handlebars - NOW SOLD
Oversize Clamp section, 42cm wide, approx 10cm reach and 13cm drop all c-c. 205g claimed!
Some marks on bars that will be covered by tape or stem clamp so look great when fitted. The Ergo style is not as deep as some and the bends aren't too tight so these feel really good in your hands, just too much reach and drop for my fit.
Deda Newton Stem - NOW SOLD
Matches the bars 100mm length oversize clamp. It's in great condition too.
Campagnolo Xenon Brake Lever/Gear Shifters 9sp
LH gear shift lever broken, Some wear on hoods from use. The internals are fine and the RH lever is in full working order. Includes internal cables (fitted to a 51cm frame so may be a little short if fitted to larger bikes). I replaced these with Ultrashift Veloce 10spd shifters as I couldn't find straight replacements for that a cheap price.
£30 plus £5 p+p
Campagnolo Champ Triple Front Mech 31.8 clamp.
In good overall condition
£7 plus £3 p+p
Stronglight Triple Chainset NOW SOLD
28/38/48 rings 170mm arms. Inc Eng Thread BB
Good overall condition although some light scratching on silver spider (but not on left hand arm). No major wear to the rings so plenty life in this - good for a winter bike/commuter or tourer. Only changing as upgraded to a 10sp compact setup that all started with me breaking my left hand shifter.
Campagnolo Veloce Cassette 9spd 12-23 inc lock ring
Used for maybe 6-700 miles, put on my winter bike to give me some harder gearing when using the triple chainset. Now I've ended up changing to a 10sp setup I no longer need this.
£15 plus £4 p+p
BBB or Miche Cassette?? Not sure of make but 9sp Campag fitment 13-26, no lock ring.
Originally fitted to my winter bike but replaced with 12-23 one. No major wear as maybe 1200 miles use.
£9 plus £4 p+p
Wellgo Platform Pedals, NOW SOLD
MTB/BMX use or even commuter
• Body: Aluminium • Spindle: Cr-Mo CNC machined • Bearing: DU / Sealed, very smooth
slight scuffing on edges due to bike being laid down on the ground. Only used about 50 miles on the wife's bike before we sold it as she wasn't using it.
Crank Bros Candy Pedals and cleats NOW SOLD
Some scuffing on edge of one pedal but otherwise good to use and serviceable. Only changed as I put road pedals on my bike.
£15 plus £4 p+p
Acor Bar Extender - Standard Bar size
Bought the wrong size in error and took too long to return.
£4 plus £2 p+p
£30 plus £5 p+p
£7 plus £3 p+p
£15 plus £4 p+p
£9 plus £4 p+p
£15 plus £4 p+p
£4 plus £2 p+p
