Leodis
- Moortown, Leeds
Selling this set of 2013 2-way fit (both clincher & tubeless Campagnolo freehub. This wheel set has done 130 miles as I have a replacement set and no longer need this set. Zondas in the price range are hard too beat. There is a slight scuff on the rear decals but nothing major and can easily be fixed with new decals (as pictured).
The information regarding the wheels below, the RRP for these is £479 new so these is a cracking deal for a wheelset hardly used, to you guys £300
ps - Yes I know I need to stripe that crap wallpaper... I'd rather be cycling though
Top Features of the Campagnolo Zonda 2 Way Fit Clincher Wheelset
Wheel Features:
The milled rim reduces the peripheral weight of the rim and makes the wheel extremely reactive
MoMag(TM) allows the external profile of the rim to be free of holes
Dynamic Balance(TM) ensures every point of the rim is counter-balanced by an equal weight on the opposite side
Aerodynamic spokes using the Spoke anti-rotation system (allows the spokes to maintain the best aerodynamic position)
Spoke count: front - 18 aero spokes, rear: 21 aero spokes
Hub - oversized flange on the drive side: increases the torsional stiffness, increasing reactivity at each change in rhythm of the pedal stroke
Aluminium hub body: provides a high degree of lateral stiffness
Aluminium axle: reduces the weight of the wheel
The Zonda wheelset has been strengthened thanks to MEGA G3. In the standard clincher tyre versions and 2-Way Fit, Zonda raises the performance level, boasting greater performance and more aggressiveness. A great wheelset for racing.
MEGA G3 on the rear wheel makes Zonda 2013 range the benchmark wheel in the market providing greater torsional stiffness and greater side stiffness that transform into greater energy transmitted to the wheel.
MEGA G3(TM) spoke pattern: perfect balance of the spoke tensions on both sides of the wheel. Reduces stress, increases transversal rigidity and the transmission of power to the wheel. MEGA G3(TM) eliminates vibrations even with "heavy" cyclists.
Wheel Features:
