presta
View: https://twitter.com/hackney_cycling/status/1842527626625229161
(I'm not talking about riding on the pavement.)
He does a quick shoulder check as the truck approaches, perhaps as a consequence of hearing it coming, then jinks left to use the (empty) pavement.
No he didn't. He was heading for that island all the time. There was no "jink" at all.
As Bristolian says above, that wasn't a "split second decision", that was him thinking that narrow road as it passses the island isn't safe, so use the island to avoid it.
The people "at fault" hgere are those responsible for that crappy road design.
At the 4/5s mark there's is a right hand shoulder check. Then this (not heading for the pavement)...
...after which there is a definite move to the left.
From what I see they heard the truck, had a glance, did a rapid dynamic risk assessment and took the pavement.
That's why I posted it. Riding in the mouth of the left turn so you leave yourself in the position of needing to swerve right into the path of the traffic to avoid hitting the island was madness. Once you've vacated the traffic lane you've put yourself in a position where you need to give way in order to get back into it again. Bikeability advocate Primary Position because keeping left is just inviting an unsafe overtake.if I was riding on the road I would have stayed a lot further right than he was
That said, if I was the lorry driver I'd have anticipated that he was likely to swerve right.
