I have just returned from a meeting about a proposed local "cycleway" and need a rant.
The proposal s for a "cycleway" parallel to a reasonably busy rural B road between two villages. Currently there is no specific provision for cyclists on this road, who have to join the main traffic.
Local farmers have expressed concern about the safety of cycleway users at field entrances. The solution decided upon by the committee - put chicanes on the cycleway to slow cyclists down at every single "dangerous" field access point (an average of one per 370 metres).
I pointed out that this would deter a great number of cyclists since it increases journey time, increases physical effort required per journey and risks damage to bikes. I was told that this "cycleway" was being designed "for families" and it was unreasonable of my to expect that the cycleway should be of use to cyclists. The primary aim was is encourage people to cycle, not to provide a safe and usable route for all cyclists.
There will only be adequate and safe provision of cycling facilities in this country when it is recognised by those deisgning so called "cycleways" (the clue is in the name) that bikes are not childrens toys but a viable transport method, and cycle facilities are designed with cyclists in mind.
