Smelly Helmet
JDoughnut
Stevenage
I have heard ALLLL the jokes.... but I really suffer from a smelly helmet.. I sweat loads... and currently wear a Ionos and it stinks... of a kind of wee smell. I hose it down and fabrieze it etc.. still stinks... is there anything I can use?
Cheers
Cheule
Coventry
Cheers
Would you be able to get away with tying it up in a blanket or some such, and bunging it in the washing machine?
battered
How about chucking it in the sink with some soapy water and just giving it a wash with a soft sponge?
(you can do the same with your bike helmet):tongue:
palinurus
Velo, boulot, dodo
Watford
Has it got removable pads inside? remove and wash.
I clean the straps by allowing them to soak in a bowl of a solution of washing powder overnight, then rinse them afterwards. You could add a bit of milton to the water perhaps.
Replace the helmet pads - husband has just done this. LBS should be able to order them in for you.
If the originals have been there a long time they've probably got permastink and are past it. New pads solves the problem!
Norm
Be careful spraying stuff into a helmet, you could react with the polystyrene and reduce its protective qualities.
Maz
I say remove the felt pads and throw them away. Don't put replacement ones in.
Take the helmet into the shower with you when you have a shower. Hang it out on the washing line to dry out.
