What am I doing wrong? As much as I practice them I still can't do big long hills. I stay in the saddle, lean right forward but if its steep I feel my front wheel lifting or slipping. Any advice?
It is true that you can get so much torque with a low gear that it is easy to wind the front of the bike off the road if you lean back. It is also easy to make the rear wheel slide if you lean forward too much. The problem is that you will probably want to use a low gear on a very steep hill!Probably a bigger gear. If you are spinning it can cause the front to lift more. Keep seated and shuffle forward if this is happening.
I doubt if weight has anything to do with it. I weigh 20st and I start kangarooing it every time the gradient gets anywhere near 20%.I'm pretty light too wondered if that would make any difference?
If you have front suspension forks the longer the length of your forks the worse this will be as well - so a 140mm travel will be more prone to lifting than a100mm.
