A while ago I noticed that my old Raleigh was making a somewhat odd noise from the drivetrain under load. It has a 50/40 chainset and 14-28 freewheel. The noise manifested itself as a sort of repetitive pinging while pedalling; only on the 40/20 sprocket combination. Now after a few more miles it seems to be doing it on other gearing combinations too.
The noise is pretty consistant; a bit louder with more load but there constantly and not periodic with pedal strokes as you get with a failing BB. The BB seems good with no sidefloat in the cranks that I detect.
The chain is worn and needs replacing; I've not bothered oiling it (it doesn't squeak) due to the impending replacement although as usual I'm dragging my arse getting this done.
I guess the first port of call is to get the chain sorted but I'm a little dubious in case this indicates terminal wear elsewhere in the drivetrain or some other horror!
Any thoughts most welcome
