I'm looking for a bit more speed and to help my Bontrager Satellite plus' last a bit longer as they're a great winter tyre. My thoughts were to buy something super-slick and I came across these, which seem good value given the chain reaction cycles additional 10% off code. I did a quick search for specs and found this set of specs which doesn't seem promising.
Michelin XC Road
Specifications
Weight 420g
PSI 29-58PSI
Tire Bead Steel
ISO Diameter 559 / 26" mtn
ISO Width 36mm
Color Tread/Side Black/Black
Tire Type Clincher
Tire Diameter 26"
Tire Use Road
33 tpi casing
What is a TPI casing? It seems that the lower you go, the less PSI you can run, these seem very low, only allowing 58PSI max. I currently run 26 x 1.5 tyres, 85PSI in the rear, 70 in the front and having had lower pressures over winter I really feel the difference running higher pressures. It seems to me these tyres aren't going to be the right thing. Is it actually worth going for a full slick for the summer months, or something like Continental Sport Contact with a miniscule bit of tread?
Michelin XC Road
Specifications
Weight 420g
PSI 29-58PSI
Tire Bead Steel
ISO Width 36mm
Tire Type Clincher
Tire Diameter 26"
Tire Use Road
33 tpi casing
