Skipping Gears
Globalti
It could be that your chain is too slack and is bouncing around and shifting inadvertently. How old is the transmission?
Globalti
Well what model year? How well has it been maintained? Can you measure the chain wear? Why was it sold?
All of these questions will give you clues to the cause of the problem. A well-maintained chain and transmission shouldn't skip in any riding conditions.
Just a photo of the bike from the RH side along with a close up of the RD and cassette will help others on here to make suggestions.
Dogtrousers
Lefty tighty. Get it righty.
Maybe this will help.
http://www.sheldonbrown.com/autoshift.html
The usual cause of the problem, though, believe it or not, is the cable guide that the derailer or hub shifter cable uses to get around the bottom bracket. As you pedal the bike, the frame flexes from side to side. This causes the gear cable to get tighter and looser with every other pedal stroke.
If the bottom-bracket cable guide has too much friction, it can act as a one-way clutch, pulling the cable down from the lever, but not allowing it to retract on the opposite pedal stroke. In many cases, greasing the cable guide is all that is required.
I can't help, and I don't vouch for the above advice. Just thought it may be of interest. It's a problem I sometimes get on my olde worlde friction shift bike if I don't do the levers up tight but not with indexed gears.
Also google "ghost shifting".
Globalti
Dont'cha just love it when you offer advice and the OP can't be bothered to come back with any facts at all?
subaqua
What’s the point
Leytonstone
Apologies, didn't realise there was a timer on! :notworthy:
Anyway I seemed to have fixed it myself now with a bit of a play around and some lube :smile:
Thanks for the advice.
its like speed chess . or countdown .
glad its something simple.
i need new chainrings , chain and rear sprocket as i have done rather more miles than i thought and its slipping under pressure . the teeth are proper worn on all items ( except chain as thats got no teef)
Dogtrousers
Thanks for the post. It caused me to go and read a new bit of the vast array of Sheldon Brown's writings. If it happens to me, I'll be ready for it now.
