On my Trek X Calibre, I have found the front skewer is very hard to tighten due to the way the 'nut' and the lever end sit in the recess of the forks. I can get it fairly tight, but not enough for my liking, and I get a small bit of wander on the front wheel, which I'm not keen on. I'm pretty sure it's not the wheel being out of true as when it's first re-fitted there is hardly any movement, but after even a short ride you can definitely see a bit of wander at the wheel.
Can I buy a longer skewer and then add washers of some sort, or is this a design fault or common problem? The shop where I got it from are great, so I'm happy to take it back there and see what they say, I just wondered if anyone else had had a similar problem and how they sorted it. Thanks in advance.
