night cycler
- Rotherham (near town)
I’ve always had conventional type axles on bikes. I’m not familiar with the skewer axles. I want to be sure that I am tightening the axle by the correct amount. How do I know when the axle is tight enough (or tightened too much) before I lock the lever over? I asked a guy recently, and he explained that you hold the nut end, then turn the lever end until it is nearly as tight as it will go, then lock the lever over. Is this the correct method?
