a.twiddler
Here are some pics of the Sinner Comfort trike I acquired recently.
It has some interesting features. It has a two stage drive with a chain to a Nexus 7 hub gear then another chain from a sprocket bolted to the body of the hub gear to the rear axle. The rear axle drives both wheels through a double freewheel system theoretically giving drive even if one wheel slips, unlike a differential or single wheel drive system. The height of the hub gear suggests that if fitted with a derailleur system hub the changer arm would be kept higher off the ground than you would expect with a small wheeled bike. Bottom gear works out at about 26" which doesn't seem low enough to me. The Linear is 17.5" approximately.
It has a double chainwheel on the front, but no changer or conventional post. The square protrusion behind the chainwheel looks as if it's designed to hold something, maybe a post for a light or computer, or maybe a custom derailleur post.
The frame is aluminium, the fork is steel. It has rubber block rear suspension. I've fitted a chain tensioner using an existing rear derailleur mounting point to make it easier to adjust the pedal to seat distance without having to mess about with the chain and eventually to fit some sort of front changer. The main frame and boom are a box section but unusually are rotated 90 degrees so the angles are made a visual feature. The mudguards are narrow but are substantially made. It doesn't feel particularly heavy to me but I'm not a weight weenie.
The seat came with some custom made rods so it can be mounted a bit more upright. I've tried it in the lower position but didn't get on with the supplied headrest, which is necessary at the lower angle so I'll use it like this until/unless I find a more suitable headrest.
The lot is finished in a cheerful tomatoey red.
It came with a rear frame extension and a large cargo box but I've left those off for now until I've finished fiddling with it.
Brakes are what look like old school BMX type twin pivot caliper brakes by Saccom. I hope that they will be at least as effective as the Dia Compe Big Dog on the rear of my Linear.
Just got to sort out a mirror and some lights before I do a test run.
