Recommend studying a set of gear tables. The Sheldon Brown site has one, then you can work out what the different combinations of front/rear sizes equate to in inches. If you are thinking that your N+1 will be a single speed, count the teeth on the MTB gears you find most comfortable, work out the equivalent size in inches, then you can work out what you will need on the single speed.
Typically for commute/leisure, it will be 65-68 inches
For racing(time trials) it is likely to be over 85". But time trials are usually on flattish terrain and the pain doesn't last for much more than an hour.
But all depends on the terrain and your fitness. Once you get a SS, you will spend hours and a few pence experimenting with different combinations to get your ideal ratio. Lots of fun.
Keith
