I'm sure that this subject has been done to death so apologies in advance.
I have an old Raleigh "Boulder" MTB lying about. It wasn't a bad bike in its day but the gears have seized and I'd like to convert it to a single speed on the cheap because I am skint. The bike has horizontal drops. Would I be able to just leave the chain in the middle chainring, change the hub using a kit and adjust the chain tension by adjusting the back wheel in the drops, without using a tensioner?
Would I need to shorten the chain and is this easy? It's only for going to the shops on BTW.
Cheers!
Cheers!
. I'd heard that you could use an eight speed conversion kit and just leave out a spacer though? Thanks a lot for your help, amy further advice would be much appreciated.
