Trevrev
- Southampton
Hello fellow cycling friends.
I've just cleaned up my old Kona Dew Delux that's been hanging around in my shed.
Thought i'd lose the triple front chainring and go single. I never use the smaller rings. Makes sense. Looks tidier too.
Ok, Too simple. Moved the large 48 tooth ring to where the middle ring was. All lined up beautifully.
This is 9 speed by the way, 32/11 cassette. I put a chain guide where the front Mech was, just to stop the chain dropping.
Just hasn't worked. The chains not dropping lots, but once is enough. I'm putting the chain back on at least once on my trip to work and at least once on the way home.
I've just changed the rear Mech for a more rigid one. Still not worked.
Went to the Local bike shop, with the thought of getting a narrow / wide ring. Although max is 36 tooth, rather have the 48. They said it wouldn't work. Nor would a clutched rear mech.
I'm at a loss. Any advice would be grateful.
I know this is becoming a common conversion. Not sure why i'm having so many problems.
I hope that all makes sense.
Thanks.............. Trev.
