AlanW
- Not to sure?
After reading many reviews, at the start of the year I decided to give the Silca Super Secret Chain blend a try on one of my bikes. Its certainly not a cheap route to go down, but I was hoping that if the reviews were right, then long term it should pay for itself and some.
A bag of 500g bag of Silca Super Secret Hot wax granules is around £40, then the top up bottles are around £25 for a 120ml bottle!
Then of course you have the faff, and it is a faff of cleaning the new chain of all its factory grease etc. So at least three large jam are required, mineral spirts in one, degreaser in one and Isopropyl alcohol in the final one! Then wash it all in hot soapy water and hang to dry, so yes a right royal faff. On the plus side, you only have to do it once, thank heavens.
However, once done, you have spotlessly chain that will, after hot waxing, always look the same as well as being super quiet. I re hot wax the chain every 1000 miles or so, and if I get caught out in the rain, wipe the chain down with a lint free cloth and simply a drop on each link from the top up bottle.
I've since done all my bikes with the Silca hot wax treatment and I honestly cannot find any pitfalls about using the product at all, other than the initial cost and the degreasing of new chains. The chain life has extended quite significantly and I'm yet to replace any of my chains and none are even close to reaching the 0.75mm wear limit, taking into account that I do my fair share of riding per year.
However, Silca have introduced the Ultimate Chain Waxing System, and combining this with the Silca Stripchip Hot Melt chain degreaser, as I see it, this is a game changer as it does away with the pre hot waxing chain degreasing process and multiple jam jars and lost time. You simply add one square of the Silca Stripchip into the hot wax in the melting pot and it degreases the chain at the same time, and I quote:-
Silca Stripchip Hot Melt Chain Degreaser
Silca’s StripChip removes the need to degrease your chain before waxing. Its innovative degreaser additive will remove factory grease from your new chain at the same time as waxing, with no prep needed, making the chain waxing process easier and more efficient than ever before. The StripChip Chain Degreaser is designed to be used in conjunction with Silca’s Secret Chain Blend Hot Wax.
This will now make the whole process so much easier, but of course its Silca, so its not cheap unfortunately.
View: https://www.youtube.com/watch?v=GJKNFzQHHgo
