shouldbeinbed
Rollin' along
- Manchester way
Just a very quick question, will WE40 left at least overnight, judiciously applied heat** and a big hammer used on a piledriver work the same way on the siezed in locknut from the bottom of a quill stem the way it does on siezed pedal threads? Not sure with it being a bigger thicker chunk of metal with a larger surface area to have rust bonded across?
** I imagine I could make quite a Mt Vesuvius effect by firing a blowtorch up the WD40'd tube![Wink ;) ;)](/styles/default/xenforo/smls/wink.gif)
