). Or you could just make sure your bottle cage bolts and seatpost are greased and the water will have no way in in the first place.Usually, down the seatpost, although a good layer of grease should stop that.asterix said:How can water enter the frame of a well oiled bike?
ASC1951 said:Usually, down the seatpost, although a good layer of grease should stop that.
Not being a physicist I suspect that it will get in to the frame of any bike because even if it is watertight it won't be airtight. Take it out of your warm house, the air in the frame cools and sucks in moist air from outside, that condenses on the inside of the frame and water droplets trickle down to the BB.
Nor those in grass houses stow thrones, as I recall.asterix said:Those who live in warm houses shouldn't store bikes.
Neither of my two bikes have every leaked (as far as I know) which is why I was so surprised at the advice in the original C+ article.fossyant said:All my bikes are steel....and non leak...
Chris James said:I remember when i did my MSc in Corrosion that one of the case studies was drain holes in car doors, working on the principle that water will always get in and it is better to let it out than let it build up.
Personally I doubt it makes much difference eitehr way. If you know your bike has been ridden through a lake it may be an idea to try to drain it, otherwise don't worry too much.
Likewise I have had frames with sealed and open breather holes and have not noticed either being more long lived.
