That sounds like a tall person speaking. I have the smallest serious mtb frame that Merlin would let me buy (the only smaller adult frame was a bmx-er and as they pointed out my wheels wouldn't fit) but the reach is still too long for my short body (and long (relative) legs - I have a 400mm Easton seat post on max) and knackered back so I have a 60mm stem. I like a low position and the seat is level with the bars, so short reach was the only way to accommodate this. Steering isn't what I would call twitchy as I can ride hands off no problem - which is a function of the frame angle and fork not the stem length. So, in conclusion, it depends on your bike frame and don't dismiss a short stem out of hand.kyuss said:Personally I stop way before 60mm. If you're needing a stem shorter than 80/90mm on a road bike then you've got a frame that's too big.
Fiona N said:That sounds like a tall person speaking. I have the smallest serious mtb frame that Merlin would let me buy (the only smaller adult frame was a bmx-er and as they pointed out my wheels wouldn't fit) but the reach is still too long for my short body (and long (relative) legs - I have a 400mm Easton seat post on max) and knackered back so I have a 60mm stem. I like a low position and the seat is level with the bars, so short reach was the only way to accommodate this. Steering isn't what I would call twitchy as I can ride hands off no problem - which is a function of the frame angle and fork not the stem length. So, in conclusion, it depends on your bike frame and don't dismiss a short stem out of hand.
Steve Austin said:And riding no hand with a short stem or long stem doesn't prove anything. you could ride with no stem attached and still have a very twitchy steering bike
