Yeah the shock looks clean, will any silicone spray do ?I take it the shock is clean? A dab of silicon spray might also help. They're easy to strip and service, and need it every 100 riding hours or so.
Have a gander here, quick air can service usually sorts it..
http://www.parktool.com/blog/repair-help/rockshox-rear-shock-service-monarch-4-2#article-section-2
Okay, thanks for the advice !! I'll try some silicone spray! Should I just put the spray on the inner bit of the shock ?Any should do. If its the shock rubbing on itself then a strip and look-see is on the cards.
Yeah, i looked it up and have access to a vice.Clean the shock thoroughly, spray the body of the can making sure some goes up the skirt. I don't know service prices, always done mine myself. Piece of pith if you've got a vice.
