02GF74
not found an exploded diagram of this hence asking
There is a narrow o-ring, maybe 0.5 mm in cross-section that sits on the spindle of the hollowtech II chainset - where does it go?
I am guessing it goes up against the inner face of the RH crank - so would be between the crank and the bearing cup - is that correct?
then should there be one for the LH crank too?
