Shimano ultegra 6700 rear mech compatability
Divadam14
Hi,
I'm new here & looking for some advice.
Is it possible to use a shimano ultegra 6700 10 speed rear mech with my 9 speed
Cassette & shifters?getting conflicting advice when searching the net.
Thanks
Pontefract
Hi,
Thanks
Well my 105 5701 worked with my 9sp setup, so I would imagine so, most RD are dumb and its the shifters that control the amount of shift, which is why you can't actually re-index, the 9sp chain is a little wider outside plates internally its the same, if I remember right.
TheDoctor
The TerrorVortex
Shimano rear mechs, shifters and cassettes are all compatible, except for 10 speed MTB rear mechs which need 10 speed MTB shifters.
But avoid anything called Dyna-Sys and you'll be fine. I'm running 10 speed 105 STIs with a 10 speed SRAM 11-32 cassette, 105 mechs and a 9 speed Sora compact chainset. No problems at all.
Big_Dave
The unlikely Cyclist
I'm running 10 speed 105 STIs with a 10 speed SRAM 11-32 cassette (and 12-27),10spd 105 rear mech, 105 10spd chain, 9 spd Tiagra front mech & Tiagra 9spd triple chainset. No problems here
