Twilkes
My right hand shifter always shifted up the sprockets fine (i.e. up to the largest sprocket, pushing the whole lever with my fingers) but on the last few rides I noticed it didn't always make it down to the smallest cog when clicking with my finger. I thought it was just derailleur alignment, but the last ride it struggled to get down even to the last two or three sprockets.
Halfway through that ride I was shifting up a few clicks at a time when the cable snapped in the shifter, so thought it must have been a damaged cable that was preventing the proper downshift. So new inner and outer, no problem.
But the shifter isn't working - I can't push the whole lever any further, there is resistance as if it's in the 'largest sprocket' position, and nothing is happening when I push the little downshift lever; it moves but there is no click. It's the same whether there is no cable fitted or whether the new cable is fitted and under tension.
It's been around or below 0°C for over a week, so could it just be that the mechanism froze up and it can be loosened with GT85 or something like that? The brake function of the lever also felt stiff at the start of the ride but loosened up after a few minutes. Is it worth taking it apart a little to see if there is anything obvious?
How will I find out if the mechanism is broken and it needs replacing? New shifter looks like £90. :-/
