tincaman
- Chudleigh, South Devon
I have been playing with the rear caliper trying to reduce the lever travel, but unfortunately made the onboard piston pop out too far which then started leaking from the piston. The trouble is that I can't get the piston to go back in far enough, I have drained the system down and taken the caliper off, stuck a tyre lever in there but it just won't go back in. The other piston goes in almost flush but this one sits out about 2mm, if you reinstall everything it works ok but now the caliper is off centre so I can't get it not to rub the disc. It's not the pads rubbing the disc, it actually the disc rubbing the caliper itself.
Any ideas how to get that piston back in properly?
