Evening All.
After learning from another thread about chain wear & stretch I checked mine and found it needed replacing. I'd appreciate any help/advice with the S-R-Pin. In these photos you'll see that it looks not bad from the front but at the back there is a slight protrusion.
1. Is this ok and I've just not nipped it close enough at the back?
2. Have I've pushed the pin through too far and its use is limited?
3. It's of no use and needs replaced rightaway. If so, can I put another S-R-Pin there?
