MountainSide
My jockey wheels have become more and more sketchy. The bottom one, sometimes the teeth go outside the chain and/or the teeth skip. There is quite a bit of lateral movement and they are allowing the chain to rub against the cage.
I found some replacement wheels that states compatible with my derailleur but the description says 10 speed. Are 9/10 interchangeable here?
Does the description match with worn wheels. The bottom one has very shallow teeth and the top one is quite pointy. Is there supposed to be a lot of lateral movement on the bottom wheel?
