Has anyone replaced 4 in the picture? I heard removing and re-installing 9 ('Seal ring') isn't a good idea as it gets damaged and sealing becomes poor. Do you replace that as well then?
You probably won't find that part separately, so remove carefully. The caged bearings can be replaced with loose ones. TBH check the bearing races and cones for pitting as it's usually too late if the hub is running rough.
I thought the same when servicing my son's MTB Shimano rear hub and wondered why one side was caged and one loose. Tried to fit loose balls both sides but actually couldn't get any more in as the nylon retainer was very space efficient.
