J and G's Dad
Hi all
Out on the bike this morning and I'm having a bit or trouble with the gears. When the chain is on the bigger of the two chain rings and I set it to go on the smaller ring all that sometimes happens is just a 'ticking' sound but no change, I've left the shifter (the bike uses Shimano SLA-050 control levers) in the 'lower' ring position and then 30 seconds later it will happen when i'm not expecting it!
I've tested the bike in the garage on a stand and when I make the change there is no problem whatsoever. Is my added weight an issue or is this a common fault?
Any help at all would be most welcome. I'm pretty certain I've missed some information that may help but after all, I am a newbie!!
Cheers
Jonathan
Cheers
Jonathan
