Success , buoyed up by the redoubtable S-B , l finally got the drive side out ! What a very unpleasant mess of ancient , dust and grit polluted grease inside. One thing l learned from Sheldon-B is that the b/b shell faces must be trued before fitting the Shimano stuff. Unfortunately this was not done by whoever fitted the b/b , there was a very noticeable gap on one edge of the lock ring side, and the rim of the shell is a bit chewed up. I will have to do a bit of cosmetic work before it goes for respray.
A few photos before l clean it
! and a few of the frame before stripping .
If you notice on the head tube lugs there are small diamond shaped cutouts , Carré only did these on his own frames for commissions from private customers.
