rideswithmoobs
- North West
Shimano Single Speed Freewheel 16t. Says for BMX riding but are they interchangeable and will it fit my Genesis day one ? At nearly 30 English pounds I don't want the wrong one !!!
Thanks Adrian, do you know if they are good quality ir if better at cheaper price ?
That is an unusual setup. See where it states the torque '30 ft lbs'. Is there another bit of text opposite that states the thread type? Shimano gave up threading the freehub body externally like that. It was an old design for cassettes where the last (smallest) sprocket was threaded, rather than using a lockring.
If it is a standard Shimano spline, a regular single speed sprocket for freehub use should fit.
http://www.velosolo.co.uk/andelss.html
http://www.velosolo.co.uk/shopsingle.html
It certainly looks like a narrow freehub and splined sprocket (with a BB lockring).
This has the advantages that it's much easier to get the sprocket off and it should last better, and the disadvantage that you probably won't find the sprockets in your LBS. They do seem to be available in a good range of sizes (google "splined single speed sprocket").
The spare sprockets that you can get for regular cassettes (eg from Rose) aren't really advisable as the chain will come off much more easily
That's what it looks like, but I'm going entirely by your photos.So would I be right in thinking the Genesis has a freewheel hub with the ratchet in the hub & a cog in the outer spline. ... I need a straight up splined sprocket ?
