GeekDadZoid
Today I had a bit of time to put the new chainset from Spa on to the Holdsworth and came across an issue, the front derailleur I was using is not compatible as the rear plate is one of the deep section ones so catched the 38t ring. I have the original derailleur from this bike which works flawlessly apart from the rear plate is worn through so the chain catches, but the concept is proven.
So what i need is a replacement for the FD-M100, has anyone got any ideas?
Needs to be triple compatible, 8 speed and band-on and allow for 28.6 tube. 48T big ring, 38 middle and 28t small but would like to have the option to drop to 26t.
Bottom pull too.
Thanks
Bottom pull too.
Thanks
