womblechops
- Hayes, Kent
I think if I can master my way around the minutiae of Shimano Alfine hydraulic braking systems I should be able to turn my hands to the resolution of the Middle East problems and the cure for all known diseases. However, the brakes are holding me up for now and so your kind input would be appreciated in order for me to get on to 'The Palestinian Question'.
I have suffered with squeaky rotors (in varying conditions) for years, and even the LBS has given up and refused to replace pads and bits because they were't worn, instead advising hard braking, degreasing, etc. You name it, I've tried it.
In fact I've tried it all so long without success I finally decided the pads probably were worn enough to merit replacement and so set aside this weekend to do a pad change and air bleed as all was also a bit spongy. All just about within my competency.
However: step 1 - on removal it appears that the pads are not the same shape as the ones in the Shimano parts diagram. Annoying, but solvable. I'll just put the old pads back in for now and pop down the bike shop and swap....
Step 2: I can't get the cylinders to retract enough to put the pads in then still get the rotor between them! I can't get them in with a spacer at all. So I released the pressure at the top of the system and noticed that there was no oil in the reservoir anyway. I pumped the lever to see if any rose from the bottom and 'pop' a cylinder appears now to have unseated itself and what little oil there was in the tubes (2-3 tsp) is now on my patio.
Fine, I think, I'll just recommission the system with fresh oil. But neither of the two cylinders will retract and one is standing very proud.
Do I have to undo the whole caliper to fix it? Any ideas?
, I can but empathise with your predicament
and offer a
, a
, even a
.... but practical advice, I regret, is not available from this respondent.
in the collective CC wisdom
you need !
