Small mole-grips? They will chew it though, so maybe better to have a replacement bleed nipple before going down that road.Trying to bleed my front brake with the Epic bleed kit and the bleed nipple on the break caliper is neither spanner shaped nor do any Allen keys seem to fit to make the quarter turn so I can inject the break fluid.
Any tips on how to undo the nipple?
Cheers!
. I know the calipers on my Genesis Croix de Fer are a nightmare as they have no bleed nipple, but they are cable operated with a hydraulic reservoir at the caliper.
First you should put the funnel reservoir on the lever end to capture fluid. Fill your syringe and expel as much air as possible and attached to the tube then push the tube onto that silver part first THEN undo the bleed port which is the black recessed screw at the TOP of the caliper with a hex key - only a a short way ( don't remove it!!) - then carry out your bleed. Video here:
https://www.bikeradar.com/advice/workshop/how-to-bleed-shimano-disc-brakes/
Best to remove the pads so you don't contaminate them if you mess it up and fit a bleed spacer BEFORE you start - otherwsie if you squeeze the lever with no spacer the pistons will just move out and that will cause grief
