Apologies if this has already been raised, but a quick search threw up similar problems, but no solutions.
One of my bikes has a 105 50/34 Hollowtech chainset and an 11/23 10sp cassette. As several other posters have pointed out, this results in the need for a lot of front and rear simultaneous (nearly) shifts. The problem would be much reduced for me with a 38 inner.
So I got an FSA 38t 110 BCD inner (Shimano doesn’t do a 38) which fitted OK, but resulted in the inner ring being about one mm further inboard than the original – just enough to allow the chain to fail to engage with the inner ring on front downshifts. The difference isn’t much (eg an 8/9sp chain would probably be OK) but it’s enough that no amount of front mech adjusting will make it work.
So the simple question is: does anyone know (based on first hand experience) if some other specific brand/model of inner ring will work?
Thanks.
Thanks.
