Shimano Centerlock Rotor Installation
Conrad_K
unindicted co-conspirator
I have a Shimano hub with brake splines, and a rotor with lock ring. Neither came with instructions.
What am I supposed to put on the splines and the lock ring threads? Regular grease, waterproof silicone grease, or anti-seize?
Cycleops
Accra, Ghana
Any you like but not too much.
I like Skol
A Minging Manc...
Nothing! Really no need to lubricate this point at all. Carefully tighten to the recommended spec and that's it. Anything you put there is almost inevitably going to leach out onto the brake surface and contaminate the brake pads.
  • Like
Reactions: C R
figbat
Retired slippery scientist
This is the sort of thing you want to stay tight. On brake disc bolts, Loctite is used. Not sure that a large thread like a rotor nut would need thread lock but I’ve also never used a grease and never had a problem removing them. That’s on MTB wheels that see all weathers.
  • Like
Reactions: C R
fritz katzenjammer
Der Ubergrosserbudgie
Nothing! Splines or threads… Dry, dry, dry…
I work on these daily, the factory build the bikes with this assembly dry, I’ve never seen one seize in use and I always assemble them dry when servicing them.
Conrad_K
Conrad_K
[suspicious squint] I guess I'm used to equipment where no threaded parts are assembled without antiseize, grease, or threadlocker. Bare (well, anodized) aluminum on aluminum would be a serious mistake in most applications.
