GrandadRob
- North Herefordshire.
Do all Shimano road bike cassettes thread on to the wheel. Need a new one, but want to leave the old one on until I get a replacement. Thanks
No, I don’t know what I have. So it seems like I must remove the old one first to see. I can always put it back until the new one comes.The answer is no, they slide onto the freehub body in yellow as above and secure with a lockring. Older freewheels did.
Do you know which you have?
If you take the back wheel off you may find that there's a code stamped on theNo, I don’t know what I have. So it seems like I must remove the old one first to see. I can always put it back until the new one comes.
Which will be a freewheel block; NOT a cassette. Good news is they're cheap. Unless you're a ninja, I recommend you ask your LBS to remove the current block (take just the wheel in). And buy a chain there which they'll cut to length (provided you take your old chain in). Then with a quick link, you can screw on the new block yourself and fit the chain. Something like this:Cruising at low pressure all ok, but in 4th and 5th of a 6 ring set it slips.
the vice method described above is your best bet for getting it off. Very hard to get enough purchase, even with a big adjustable spanner on the removal tool, otherwise.Thanks very much. I do have a removal tool. This thread has.been very informative, learned a lot.
Great. I'd observe that the tool for a freewheel block is not the same as for a cassette (Shimano or Campagnolo) and . . .Thanks very much. I do have a removal tool.
