shimano caliper leaking
SolemnWeasel
Edinburgh
I am now convinced that the BR-m525 rear caliper of mine is leaking - with light reflection I can see oil weeping in the middle when I brake. I don't think it is the piston seals gone.
That explains why they squeel extremely and loose power for the second time now.
I am wondering - should i replace with the cheap Shimano BR-MT200, or try to troubleshoot and maybe replace the O-ring? Or buy better caliper.
I hope I could reuse the lever and hydraulic line.
Never replaced hydraulic parts yet - I understand I need an olive and 'barb' to install?
Thanks for tips.
wafter
Oxford
When you say "weeping in the middle" do you mean between the two halves of the caliper?
IMO always worth trying to save stuff; while you have nowt to lose if you're prepared to replace it anyway. Presumably the caliper halves just bolt together with fluid drillings sealed with O-rings / a gasket / sealant?
IIRC I vaguely recall watching a caliper strip on youtube; didn't seem terrible.
EDIT: Not your caliper but I'm sure they're all much of a muchness; looks straightforward with the only potential pain being piston removal if you don't have a source of compressed air.
S
SolemnWeasel
Edinburgh
Yes, it is weeping / leaking between the two halves - very difficult to see - I only noticed when I saw that light reflection changed when pressing. I might go to a bike self repair place and see if they have o-rings for it.
S
SolemnWeasel
Edinburgh
The solution to that is that I bought a new brake caliper, a BR-MT410 Shimano one. I installed it, only to see it is also leaking in a similar way.
Just to note the front brake is also an m525 and has absolutely no signs of leaking.
The MT410 can be seen here
View: https://www.youtube.com/shorts/aMT5XIqDvE0 (loud noises).
In addition to the 525 caliper - I opened it and the o-ring looks to be around 6mm and a bit in diameter.
Measured on the resceptacle for the o-ring - 6.3mm, the oring itself looks to be 6.1mm - I think I am reading this correctly.
Probably a 6mm o-ring will be fine then, preferaby thicker.
Loch side.
I have a huge selection of O-rings. If you want some, I can probably help. You need to measure the ID and the diameter of the "O". for instance, 6.5 x 3
